Hi there,
My machine spec is:
Asus M4A87TD EVO
AMD Phenom II X6 1090T Black Edition
G.SKILL Ripjaws X F3-12800CL9D-8GBXL memory
Asus GeForce EN210 graphics (512MB)
When I first tried to boot the Windows installer DVD, it hung at the "Starting Windows" screen. After googling, I found a thread somewhere and the person had a very similar setup. He said if he took the second stick of RAM out of the machine, then installed Windows, it'd work fine... then once complete, re-install the second stick of RAM and it'd pick it up and all would be fine...
So I did this, and it worked... until I'd done two or three reboots. After this, it'd get further than the "Starting Windows" screen, but would hang when the cursor came up. No login screen.
If I rebooted and took a stick out, it would be OK... So I ran Memtest on the suspected faulty stick and it was fine. Swapped them round, ran the test again, still came out fine. Put them both in, ran the rest in again, fine. Swapped them around a few times to try every possible combination and each time the tests came out fine.
Booted into Windows and again, it was running OK, but I noticed that my download speed was limited to roughly 15kb/s on any website, while my laptop could get 2.0mb/s on the same files... Moved the PC to get better wireless signal, so now in a different room... Booted up, and it locked up after about 5 minutes.
Took a stick of RAM out, booted up OK, download speed now strangely restored to 2.0mb/s, but after 15 minutes, it locked up again!
Swapped for the other stick, same thing.
I've read the sticky and tried all kinds of combinations and the longest it's worked for is about 18 minutes.
If I'm honest, I don't understand any of the settings on the Ai Tweaker tab in the BIOS. I've never had a motherboard with settings like this before and never messed around with overclocking or anything...
Any help would be greatly appreciated.
My machine spec is:
Asus M4A87TD EVO
