ASROCK Z68 Extreme7 Gen3 Ripjaws ?
  • ASROCK Z68 Extreme7 Gen3 Ripjaws ?
    Hello Support
    Planning a new build with the ASROCK Z68 Extreme7 Gen3 mobo and using the matched/tested 4GB X 4 set = 16GB of GSkill RipjawsX F3-17000CL11Q-16GBXL
    DDR3-2133 (11-11-11-30-2N) that has the XMP profile.
    1. Will this memory work with the board as it's not on ASROCK's memory support list ?
    2. If this memory will work on the board besides enabling the XMP profile in the BIOS (not sure where that feature is at the moment) will I need to
    change any voltages or other settings and/or manually set timings in the BIOS in order to keep the stable at 2133 ?
    3. Is it recommended to use just 2 dimms (8GB) in the correct 2 mobo slots on a new install then add the other 2 dimms in the remaining 2 slots
    (to make 16GB) later on after the memory has proven to be reliable and stable ?
    Any guidance and tips would be greatly appreciated
    SaphireX
    ASRock?Z68 Extreme7 Gen3-Intel?Core i7-2600K-Corsair?H100-16GB G.SKILL?Ripjaws DDR3 2133-(2)ASUS?ENGTX560 TI in SLi-Mushkin?Chronos Deluxe 120GB FW332 SATA 6.0 Gb/s SSD-(2)WD?2002FAEX 2TB SATA 6.0 Gb/s-HP?DVD Writer SATA Model 1260i-Plextor?Blu-ray writer PX-LB950SA-PCP&C?Silencer Mk II 950W-Inwin?DRAGON RIDER case-APC? BR1500LCD UPS 1500VA w/AVR-Viewsonic? V3D245
    3D LED display @120hz-Win7? Ultimate 64
    Ensure you have the latest BIOS, then install the sticks, enable XMP select the 2133 profile and should be good to go....
      Thank you Tradesman for the quick answer
        No problem, let us know how you like them.
          Hi Tradesman
          Well I just finished my new build with the ASRock Z68 Extreme 7 Gen 3 board the other day and am happy to report that both before updating the UEFI from the original 1.0 version to the latest 1.3 version that all 4 sticks = 16GB were properly detected.
          Your advice to select the XMP profile 1.2 for 2133mhz was simple and everything works as it's supposed to...
          Best Regards! from a very pleased G-Skill Customer
          SaphireX
            Glad to hear it, Enjoy!
              ripjaws
              Almost 3 months later Tradesman and still going strong with this RAM and a mild o'clock set by the XMP profile...Highly Recommend this memory
              Happy Holidays
                Glad all is well, makes for a great Xmas!
