ram module: F3-10600CL9D-2GBNQ ddr3 PC10600
motherboard: BIOSTAR TA790GX A3+
processor: AMD Phenom II X3 720
The LED in the motherboard keep indicating that there is a problem with the memory and I'm not even able to see the bios to start.
I have already try to put each part memory on every slot, but nothing work.
Also I already try to clear the CMOS, but it doesn't work either.
This is so frustrating.
Do you have any idea to fix this?
Thank you.
Best Regards
Thank you.
Best Regards
