ASRock H67M and F3-10666CL7D-4GBRH kit
  • ASRock H67M and F3-10666CL7D-4GBRH kit
    I am making this post to hopefully help anyone else who tries this combination. This forum helped me out so I want to contribute back.
    Motherboard: ASRock H67M-ITX
    CPU: Intel G620 2.6GHz
    UEFI BIOS: 1.10 or 1.30
    Memory: GSkill F3-10666CL7D-4GBRH
    This board would not post at all with the default BIOS settings and this memory installed. This was true for me with 1 or 2 sticks plugged in. I thought the first kit I had was DOA and hassled with a RMA to Newegg. When the second kit also would not post I knew I had a different problem. I could run it fine with some cheap CL9 memory sticks.
    When I manually configed the BIOS to:
    DDR3-10666
    7
    7
    7
    21
    2N
    VRam - 1.545
    The board started booting fine with this memory kit. It does make a difference because my WEI RAM score went from 5.5 to 5.9.
    I hope this helps!
    Thanks for sharing the info, I'm sure it'll help others out there
