I cannot get my x.m.p profile to run this memory at its rated speed without running ridiculously high voltages 1.7+dram bus.
This ram is hardly plug and play my asus iii formula supports this ram and x.m.p.
If there is a way to get this ram to operate at its rated frequency "safely" I would like a step by step process showing me how.
This is a random template of my bios with settings that do not reflect my own but ill fill in settings i know off the top of my head. you can use this template to help guide me to set this ram up properly.
My dram bus voltage is 1.6 dram core 1.42 . at 1.65 it will not go past 1900 mhz.
BLK 180 x19
Asus RampageIII Formula
Extreme Tweaker
Target CPU Frequency...............: 3.4GHz
Target Dram Frequency.............: 1800Mhz
LN2 Mode
QPI Load Line Calibration
_____________________________________
Extreme tweaker
Sync Mode..................................: Disab.
A1 Overclock Tuner......................: Manual
OC from CPU Level Up...................:Auto
CPU Ratio setting..........................: x19
CPU Turbo Power Limit..................:Enab.
<CPU Configuration Sub Menu>
CPU Ratio setting..........................:x19
C1E Support.................................
isab
Hardware Prefetcher.....................:Enab.
Adjacent Cache Line Prefetch.........:Enab.
MPS and ACPI MADT Ordering.........:Modern
Intel(r) Virtualization Tech...............:Enab.
CPU TM Function.............................
isab.
Execute Disable Bit..........................:Enab.
Intel(r) HT Technology.....................:Enab.
Active Processor Cores.....................:All
A20M..............................................
isab.
Intel(r) Speedstep(TM) Tech.............
isab.
Intel(r) C State Tech*.......................
isab.
*C State package limit setting............:N/A
*C1 Auto Demotion...........................:N/A
*C3 Auto Demotion...........................:N/A
Extreme Tweaker(Continued)
BCLK Frequency.................................:180
PCIE Frequency..................................:100
Dram Frequency.................................:1800
UCLK Frequency..................................:auto
QPI Link Data Rate...............................:auto
Memory Configuration Protect...............
isab.
<Dram Timing Configuration Sub Menu>
1st Information
CAS# Latency (tCL).........................:7
RAS# to CAS# Delay (tRCD).............:9
RAS# PRE Time (tRP)......................:8
RAS# ACT Time (tRAS)....................:24
RAS# TO RAS# Delay.......................:4
Ref Cycle Time.................................:60
Write Recovery Time.........................:8
Read to Pre Time..............................:7
Four Act Win Time.............................:Auto,
Back to Back Cas# Delay.....................:Auto,
2nd Information
Timing Mode......................................:1N
Round trip Latency Channel A...............:Auto,
Round trip Latency Channel B................:Auto,
Round trip Latency Channel C................:Auto.
3rd Information
Write to Read Delay (DD).......................:Auto.
Write to Read Delay (DR).......................:Auto.
Write to Read Delay (SR).......................:Auto.
Read to Write Delay (DD)........................:Auto.
Read to Write Delay (DR)........................:Auto.
Read to Write Delay (SR)........................:Auto.
Read to Read Delay (DD).........................:Auto.
Read to Read Delay (DS).........................:Auto.
Read to Read Delay (SR).........................:Auto.
Write to Write Delay (DD)........................:Auto.
Write to Write Delay (DR).........................:Auto.
Write to Write Delay (SR)..........................:Auto.
Extreme Tweaker (Continued)
CPU Differential amplitude..........................:700
CPU Clock Skew.........................................:norm al
IOH Clock Skew..........................................:Nor mal.
Extreme Engine Digi+
Digi+ Power Mode.......................................:t-balance
PWM Voltage Control...................................:Auto
Load-Line Calibration...................................:0%
CPU Voltage OCP.........................................:Enab.
CPU PWM Frequency....................................:Auto .
Extreme OV................................................ .
isab.
Extreme OC................................................ .:Auto.
CPU Voltage........................................... ......:1.12c
CPU PLL Voltage........................................... .:1.802v
QPI/DRAM Core Voltage.................................:1.42
DRAM BUS Voltage.........................................:1 .6
<Dram Reference Voltage Sub Menu>
DRAM DATA Ref. Ch.A.....................................:Auto.
DRAM CTRL Ref. Ch.A......................................:Auto.
DRAM DATA Ref. Ch.B......................................:Auto.
DRAM CTRL Ref. Ch.B.......................................:Auto.
DRAM DATA Ref. Ch.C.......................................:Auto.
DRAMAuto. CTRL Ref. Ch.C................................:Auto.
IOH Voltage........................................... ...........:1.15275v
IOH PCIE Voltage........................................... ....:1.5105v
ICH Voltage........................................... ............:1.113v
ICH PCIE Voltage........................................... .....:1.5105v
CPU Spread Spectrum.........................................
isab.
PCIE Spread Spectrum.........................................
isab.
BLK 180 x19
Extreme Tweaker
LN2 Mode
Extreme tweaker
![Big Grin](https://www.gskill.us/forum/core/images/smilies/biggrin.png)
1st Information
2nd Information
3rd Information
