Hi all.
I just got myself F3-17000CL11D-8GBXL kit. I am using an Asus P8z68-v pro motherboard with the 2600k cpu.
The bios is the latest 606. I had the previous version but upgraded thinking it would fix this issue.
In my bios the memory shows targeted memory of 2133 and the timings show as 11 11 11 30. XMP is on and set to profile 1 and it shows as 2133
In cpu-z under Memory it shows as Dram freq 1066 FSBram 1:8 11 11 11 30 2t
Under spd for each module it shows as
Max Bandwidth PC3-12800 (800)MHZ
Am I missing something in the bios to get it to read the correct speeds?
