Adding two more memory sticks same speed?
  • Adding two more memory sticks same speed?
    Hello, i have the G.SKILL Ripjaws X Series 4GB DDR3 1600 Cas latency 6-8-6-24 installed. Can i buy one more set and run 8GB with the same speed and latency?
    or will it downgrade the performance? This is dual channel memory.
    2500k 1155
    GTX 570
    Asus P8Z68-V PRO 1155
    GSKILL DDR3 1600 4GB
    Win7 64 bit
    100wt power supply
    If the two kits can work together, then the same memory spec should be capable.
