Would these two sets of RAM work with my Mobo? Asus M4A88TD-V EVO/USB3.
  • Would these two sets of RAM work with my Mobo? Asus M4A88TD-V EVO/USB3.
    I have the Asus M4A88TD-V EVO/USB3.
    I was wondering if each of these sets would be compatible with my mobo?
    [ Ripjaws ] F3-10666CL9D-8GBRL (4Gx2) / F3-10666CL9Q-16GBRL (4Gx4) -http://www.gskill.com/products.php?index=233 (Going for 2x4, not 4x4 by the way, haha! )
    [ SNIPER ] F3-10666CL9D-8GBSR (4Gx2) / F3-10666CL9S-4GBSR (4GBx1) -http://www.gskill.com/products.php?index=337
    Also, I'm not too computer savvy, can you guys tell me the difference in both of them?
    Any of the four should work with the mobo, but as suggestions: The 4x1GB is sort of a waste of time, if you only want 4GB better to go 2x2GB, you don't mention what CPU, but AMD has weak MCs (Memory Controllers) and 4 sticks put more stress on the MC than do 2. either of the 2x4GB will work with most AMD CPUs and the 4x4GB will work, but you'll want a strong CPU and can expect to need adjustments, primarily CPU/NB voltage.
      Ah for the Sniper, I was mainly aiming at 2x4gb. Here's a more accurate link to where I'm going to buy:
      Ripjaws: http://www.newegg.ca/Product/Product...82E16820231311
      Sniper: http://www.newegg.ca/Product/Product...82E16820231417
      Ripjaws seem to be $2 cheaper, haha.
      CPU - AMD Phenom II x4 955 Black Edition
        Either set will work, I know I'm a fan of the Snipers, been using quite a few lately, from 1333 through 1866 (have 16GB of the 1866 the box I'm using now).
          Sounds good! I'll pick up a set of the Snipers, $2 more and it looks pretty cool, haha. Any significant differences between the two, though?
            Just picked up a set and I can honestly say they've made a difference. Thank you gSkill, I will continue to purchase from you guys!
              Glad to hear it, love those sticks
