I was just wondering if along with changing my timing, would I need to change voltage settings on my motherboard or is just changing the timings enough. If there any other system setting I should adjust, feel free to let me know. I dont think I am getting the performance i should be.
Product Type : Motherboard
*Product Model : M4A79XTD EVO
[Motherboard Specification]
*Motherboard Revision : Ver2.0
*Motherboard BIOS Revision : 2102
[VGA Card Specification x 2]
*VGA Card Vendor : XFX
*VGA Card Model : HD-687A-ZN
*VGA Card Chipset : HD 6870
*VGA Card Driver : 11.6
[CPU Specification]
*CPU Vendor : AMD
*CPU Type : Phenom II X4 965
*CPU Speed : 3.4ghz
[Memory Specification]
*Memory Vendor : Gskill
*Memory Model : Ripjaw DDR3 1333
*Memory Capacity : 8gig
[HDD Specification]
HDD Vendor : Western Digital
HDD Model : ST3500418AS
HDD Capacity : 500gig
[PSU]
850 watt Thermaltake Black Widow PSU
*Operating System : Windows 7 64bit
[CPU Specification]
*CPU Vendor : AMD
*CPU Speed : 3.4ghz
[HDD Specification]
[PSU]
