Okay im building a new system cause my old one literally fried itself for no reason
i have chosen the following.
CPU: phenom x6 t1100
MB: Gigabyte GA-990FXA-UD3
RAM: well, initially i was considering getting htis kit of ram.
http://www.bttech.com.au/gskill-ripj...-p-240442.html
and i am wondering how this will go with this motherboard?
i have read the sticky regarding the issue with 1600 ram.
if i chose this ram what settings should i run, Oc the whole lot? or lowwer the speed of the ram?
i am FINE with OCing my CPU and have a small amoutn of experience OCing intel.
my other question is regarding if i should get either 8gb or 4gb of ram?
i intend to do some gaming, and small amount of multitasking, use of photoshop and just normal PC usage.
will i be better off with 4Gb of
http://www.bttech.com.au/gskill-trid...-p-111337.html
than the 8gb of the above mentioned ram, and also what about 4gb of this http://www.bttech.com.au/gskill-ripj...-p-218977.html
any advice or help would be muchly appreciated, along with any experience with this board and G.skill ram?
thanks guys!
thanks guys!
