Hello all!
Well, I decided I needed to move up from 4 to 8 GB of RAM, and now I'm in a mess.
My old Pi Black RAM worked all right with my AMD platform, but this new Sniper series RAM is a bit more finicky.
Specs:
- AMD Phenom X4 955 BE (rev. RB-C3)
- Gigabyte GA-890FXA-UD5 (rev 2.0 w/ latest BIOS)
- G.Skill F3-12800CL9D-8GBSR (Sniper DDR3-1600 8GB, 9-9-9-24)
I simply cannot get the RAM to run at spec. Right now, the motherboard is automatically setting it at 1600MHz with CL 11, but that is not acceptable.
I followed the instructions in this sticky, but I was still not able to get it working.
Has anyone had any luck with this RAM in a similar configuration?
Thanks in advance!
Specs:
Thanks in advance!
