motherboard:
GA-X58A-UD3R rev2.0
Processor
i7-930 2.8ghrz
Gskill Ram kit im interested to get
DDR3 6GB 1333MHZ F3-10666CL9T-6GBNQ
In the gskill site i couldnt find the model of the motherboard. I did find listed a GA-EX58-UD3R which i belive is the GA-X58-UD3R, but i dont know if theres a difference with the GA-X58A-UD3R. The kit would be to make my pc. im new to this, and trying to be careful so i dont try to use the wrong parts and screw things up
Also, another matter: apart from that kit, i would like to later buy separatedly 4gb cards (two 3x4gb kits), that could work in triple channel mode, in order to fill the 24gb capacity of the board, so i would appreciate if someone could tell me which are my best choice. Also, in the case the 6gb kit its compatible, would it work fine if i add a 12kit (one you recommend me) without crashing the machine, or provoking compatibility issues?
GA-X58A-UD3R rev2.0
Processor
i7-930 2.8ghrz
