I am assembling a new computer with new "G.SKILL Ripjaws Series 4GB (2 x 2GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Desktop Memory Model F3-12800CL9D-4GBRL".
When i turn the power on, I get a beep code that sounds like 1 long beep followed by two short beeps.
I'm using 650 watt power supply with msi 870a-54 AM3 mobo and phenom II X4 955 black edition CPU.
Nothing appears to be showing up on my 21.5'' moitor.
I'm told that the beep code I'm getting means that i have to replace the ram cards. Do you recommend that i have these sent back to the manufacturer? Is there some way to determine for sure that the ram cards are faulty?
