I'm comparing the SGskill memoery to the Patriot options and G.Skill memory at 2000 MHz is listed as 1.55v whereas the Patriot is listed as 1.65v
Does this mean the G.Skill can attain higher speeds/better timings at lower voltage? Or does it mean the G.Skill needs to run at lower voltage because higher voltages are not stable?
Here's a breakdown of the memory I'm considering: http://www.newegg.com/Product/Produc...atedMark=False
Thanks! Love my current G.Skills (x3 - 6 Gig total).
