Hello community. I just want to start off an introduce myself as Joe aka the Rabbit. I am a competitive console fighter gamer and now getting into PC gaming. I also do HD video editing and streaming. I have been osx for the last 3 years now am back to windows. I own 8 different computers ranging from osx to windows. I just built this new gaming rig and need some feedback or criticism.
I purchased GSKILL F3-16000CL9T-6GBRH 3x2GB sticks from newegg a bit ago. These are the ripjaws. On the package it says they are rated 9 9 9 27 1.6v.
Well I got them to run at 800 so thats is 1600. Here are my specs and what I have accomplished so far. I am adpet in computers but I am new to over clocking so please bear with me. SO far I didn't OC the vid card. I am waiting until I get my second one in the mail for my SLI set up. I will be pretty sick because I am getting 3 of those ASUS 23" 120HZ 3d monitors so I can do nvidia surround and 3d.
So what I am asking for is your best input in what I can do to make the memory faster? Any other input to make my rig faster would be nice. I play a bit with AI tweaker in the bios but this is what I came up with for this memory.
CPU Properties:
CPU Type QuadCore Intel Core i7 Extreme 975
CPU Alias Bloomfield
CPU Stepping D0
Engineering Sample No
CPUID CPU Name Intel(R) Core(TM) i7 CPU 975 @ 3.33GHz
CPUID Revision 000106A5h
CPU Speed:
CPU Clock 4000.0 MHz (original: 3333 MHz, overclock: 20%)
CPU Multiplier 25x
CPU FSB 160.0 MHz (original: 133 MHz, overclock: 20%)
QPI Clock 2880.0 MHz
Memory Bus 800.0 MHz
DRAM:FSB Ratio 5:1
CPU Cache:
L1 Code Cache 32 KB per core
L1 Data Cache 32 KB per core
L2 Cache 256 KB per core (On-Die, ECC, Full-Speed)
L3 Cache 8 MB (On-Die, ECC, Full-Speed)
Motherboard Properties:
Motherboard ID 65-0502-000001-00101111-111610-TYLERSBURG$A1631001_BIOS DATE: 11/16/10 18:07:45 VER: 08.00.15
Motherboard Name Asus P6X58D-E (2 PCI, 1 PCI-E x1, 3 PCI-E x16, 6 DDR3 DIMM, Audio, Gigabit LAN, IEEE-1394)
Chipset Properties:
Motherboard Chipset Intel Tylersburg X58, Intel Nehalem
Memory Timings 9-9-9-27 (CL-RCD-RP-RAS)
Command Rate (CR) 1T
DIMM1: G Skill F3-16000CL9-2GBRH 2 GB DDR3-1333 DDR3 SDRAM (9-9-9-24 @ 666 MHz) (8-8-8-22 @ 592 MHz) (7-7-7-19 @ 518 MHz) (6-6-6-16 @ 444 MHz)
DIMM3: G Skill F3-16000CL9-2GBRH 2 GB DDR3-1333 DDR3 SDRAM (9-9-9-24 @ 666 MHz) (8-8-8-22 @ 592 MHz) (7-7-7-19 @ 518 MHz) (6-6-6-16 @ 444 MHz)
DIMM5: G Skill F3-16000CL9-2GBRH 2 GB DDR3-1333 DDR3 SDRAM (9-9-9-24 @ 666 MHz) (8-8-8-22 @ 592 MHz) (7-7-7-19 @ 518 MHz) (6-6-6-16 @ 444 MHz)
BIOS Properties:
System BIOS Date 11/16/10
Video BIOS Date 05/05/10
DMI BIOS Version 0502
Graphics Processor Properties:
Video Adapter nVIDIA GeForce GTX 465 (p1025)
GPU Code Name GF100 (PCI Express 2.0 x16 10DE / 06C4, Rev A3)
GPU Clock (Geometric Domain) 50 MHz (original: 607 MHz)
GPU Clock (Shader Domain) 101 MHz (original: 1215 MHz)
Memory Clock 67 MHz (original: 801 MHz)
Storage:
IDE Controller Intel(R) ICH10 Family 2 port Serial ATA Storage Controller 2 - 3A26
IDE Controller Intel(R) ICH10 Family 4 port Serial ATA Storage Controller 1 - 3A20
IDE Controller Standard Dual Channel PCI IDE Controller
Disk Drive Corsair CSSD-V128GB2 ATA Device (128 GB, SATA-II)
Optical Drive HL-DT-ST DVDRAM GH24LS50 ATA Device (DVD+R9:16x, DVD-R9:12x, DVD+RW:24x/8x, DVD-RW:24x/6x, DVD-RAM:12x, DVD-ROM:16x, CD:48x/32x/48x DVD+RW/DVD-RW/DVD-RAM)
SMART Hard Disks Status OK
THANKS!!!!
Joe
CPU Properties:
CPU Stepping D0
CPU Speed:
CPU Multiplier 25x
DRAM:FSB Ratio 5:1
CPU Cache:
Chipset Properties:
BIOS Properties:
Storage:
THANKS!!!!
Joe
