Hello there,
I just built a new machine specified as follows;
Foxconn A7DA-S 3.0 Motherboard
G-Skill F3-10666CL9D-4GBRL DDR3 1333 mhz 2GBx2
AMD Phenom II BE 955 x4
HIS HD5750 iCooler 1 GB
The problem is, the system runs fine with one stick of ram. When i replace it with the other stick, system locks up or BSODs while starting win7. The same problem occurs when i install the both sticks. BSOD.
Perhaps one of the sticks in the kit is bad?
A friend of mine told me to tinker with memory voltages and timings but i'm not familiar with them.. Please help me!
Thanks in advance.
Thanks in advance.
