Motherboard: Asus p7p55-lx
CPU: I5-760 lynnfield
Ram: SDRAM DDR3 1333 (PC3 10666) Desktop Memory Model F3-10666CL9D-8GBXL (2x4gb)
I had built this system end of last year, no major issues however i did have to reset cmos jumper on board for it to post with the ram i had at the time which was Kingston hyperX blue 2x2gb 1333mhz (pc3-10600)
Since then I bought a dual channel kit (G.SKILL Ripjaws X Series 8GB (2 x 4GB) 240-Pin DDR3 SDRAM DDR3 1333 (PC3 10666) F3-10666CL9D-8GBXL and they worked fine in the second channel (slot_b). So i wanted to swap the Gskill to slot a and remove the kingston, but the board will not post with either Gskill at all. Mem 'ok' switch on the board never seems to resolve. But, if i put the kingston back in and Gskill in slot board posts and works fine - although in Windows System it says System Ram: 12GB (6 usable).
Is this a motherboard issue do you think?
