What is the recommended VCCIO voltage to run this gskill RAM at the 2133Mhz?
I'm using intel i7-2600K@4.7Ghz, ASUS P8P67 WS Revolution.
Previously I couldn't increase the RAM speed beyond 1333Mhz, even if I put the VCCIO voltage at 1.35V and the system will not boot into BIOS. It only boots after I press the power button to switch the system on and off 2-3 times. Even so the system is unstable and would produce error in memtest.
But after resetting CMOS, I am running 2133Mhz at 1.2V right now and after 8 cycles of memtest right now, no error found.
