Model of the motherboard: Asus P5Q3 Deluxe (Bios version 2105)
Model of the memory: F3-10666CL7D-4GBRH (2 kits = 8 Gb total)
Model of the CPU: Intel Core2Quad 8200 @ 2.33 Ghz
What is the problem?
I connected all 4 sticks, it started o.k., but with latencies 9-9-9-X, changed AI Tweaker from Auto to XMP, system restarts but doesn't boot, it goes straight to EZ Flash 2 utility and says bios might be corrputed, it will delete latest bios and replace it with default one.
I did that. Again same story (9-9-9-X), but when I change it to XMP, it restarts, but monitor doesn't show any picture (blakc screen, everything else looks/sounds normal - all vents are running, disks are spinning, etc.). In that situation I had to remove 2 sticks of ram to get picture back on.
After all that I updated bios to the latest version once again, left only 2 sticks of ram in orange slots, enabled XMP and it works perfetly (boots in Windows, no BSOD, 7-7-7-21 etc.). Passed memtest without errors.
Then I removed this 2 sticks and replaced them with other 2, but this time I put them in black slots. Again, everything works perfectly, boots in Windows, no errors on memtest.
My question is how can I make all 4 sticks run on XMP? Manual settings maybe? Wich one? I am total noob when it comes to advance bios settings.. :\
Thanks for your help,
sagy
sagy
