My System:
AMD Phenom II 955 BE 3.2ghz (not overclocked)
GA-MA770T-UD3P v 1.1 Bios is F11C
Antec TruePower 550 PSU
XFX Geforce 9500GT
F3-12800CL9D-4GBNQ (dual channel or single channel)
Windows XP Professional and Ubuntu 10.04
I am having issues getting my ram working in either 1600mhz or 1333mhz speed, ganged,unganged, dual channel, single channel etc.
I started out at 1600mhz 9-9-9-24 2T 160ns standard voltages then increased gradually, finally stopping at 1.7v DRAM and CPU-NB at 1.2v.
At any speed or voltage I do not get any errors in overnight tests of Memtest. However soon as I enter a game (tried Everquest,WoW,Runes of Magic,Lord of the Rings online) it will eventually hang and reboot.
I have RMA'd the video card and when tested by XFX they said nothing was wrong but they replaced it with a different card anyway.
I load tested the PSU with pushing the CPU cores to 100 percent while doing Burnin tests on VRAM,RAM,HDD writes/reads, watching a DVD and using USB accessories all at once. No reboots.
When I start a game it resets. I do not think its the power supply or I would think I would have seen a reboot once I had everything on the system going at once.
I have tried two different sets of RAM, different manufactures different speeds.
I have tried different graphics drivers in different operating systems (Wine in Linux) and get the same hang then reboots in both OS's.
The only thing I thought was to mess with PCI-E frequency although I am hesistant since I am not overclocking the CPU or GPU and can't find definative information on the net about what exactly it helps with or is for.
Any suggestions?
XFX Geforce 9500GT
Any suggestions?
