I bought a set of DIMMs a while back. They are rated for 1.35V, but my motherboard (ASUS P7P55D PRO) will not let me set them to anything less than 1.5V, so I'd like to know if running them at 1.5V will have negative effects on performance, stability, and/or longevity. Also, if I have to run them at 1.5V, should I overclock the frequency or something to make use of those extra volts? If so, then how do I go about doing that?
Voltage Problem -- G.Skill 2X2GB DDR3-1333 CL7-7-7-21 1.35V
Thanks for the reply, but my motherboard does not allow me to set the voltage any lower than 1.5V. I am able to type in 1.5V or higher, so I assume that if the MOBO did allow lower DRAM voltage, then it would be as simple as typing in a lower voltage within BIOS. Doesn't work. So are you telling me that there is another way to do this?
Press DEL when you boot up to access BIOS. Then hit F1 to see options. One of them should be system info. On that page it should show.. BIOS revision xxxx
Then go to ASUS support webpage, search for your motherboard, search BIOS, then see where you are at.
At that point you can download the latest, put it on a flash drive, then go back into BIOS and flash it in.
When you look at F1 options, F11 should be something about flash, which is flashing the BIOS.. sorry I forget the actual name.
