Hello
I just bought these stuff..and builted it!
Sabertooth X58+ I7 950 + Gskill F3-12800CL7T-6GBPI
I try XMP profile.. and doesn't but (gives overclock failure)
I try manually with QPI 1.35 Dram 1.5
and boots only at 7-8-7-24-60-2N!
i can't get trFC 36 only 60 !! (all other settings are auto-default , no oc at all)
having fsb:dram 2:12
what should i do?
a new problem!! the Task manager see only 2Gb ram (from 6gb)
CpuZ and bios see normal 6G BUT Everest +Windows only 2 !!
what happens here?
what should i do?
what happens here?
