Recently I purchased a pair of 2x4GB F3-12800CL7D-8GBXH RAM modules along with a Asus P67 motherboard. In the uEFI bios if I leave the settings at Auto for the RAM (9-9-9-24-1T 1.5v) and coldboot the system it will boot with no issues. When I change to the rated values for the frequency, timings and voltages (7-8-7-24-2N 1.6v) and coldboot the system it will turn on, turn off, and turn again with a message "Overclock Failed!" Then I must reenter the bios and put all the settings back to their intended values. However, once the system is shutdown and coldbooted it will go through the same process and I must input all the values once again. Is there a known compatibility issue with the F3-12800CL7D-8GBXH and Sabertooth P67 motherboard?
I've already tried to enable XMP 1600mhz profile and it does the same thing.
I appreciate any comments or information, my current specs are:
Asus P67 Sabertooth
Intel i7-2600k
2x4GB Gskill F3-12800CL7D-8GBXH RAM
EVGA GTX 570
Sound Blaster X-fi Titanium Fata1ity
Corsair HX850W PSU
Tuniq Tower 120 Extreme Heatsink
Antec Nine Hundred-Two Case
Asus P67 Sabertooth
Intel i7-2600k
EVGA GTX 570
Corsair HX850W PSU
