Can anybody help me stabilize my system further?
i7 920 D0 (Currently running 20*166 -- XMP @Auto gave me this)
MSI X58m
G.Skill F3-16000CL9T-6GBTDD (9-9-9-24-135 / 1.6v)
Dram Freq: 999.5mhz
FSB/Dram: 2:12
CMD Rate: 2T
Vcore: +0.10 (my cpu can usually run @3.4ghz with no vcore added)
PLL: 1.80
QPI: 1.44 (Am I safe with this?)
Dram: 1.60 (9-9-9-24-135-2T)
Rest is auto.. Already ran Memtest for windows with 3 instances of using 2047 each and so far QPI @1.44 has made my system pass 100% each... Any QPI value under 1.44 makes my system BSOD and give out Error code 124... Is it normal to use more QPI with these tridents?? And what else do I need to run in order to find out if my system is stable??
Basically I just wanna know if I'm ok with 1.44v QPI and if there's anything else I need to do? If anybody could share their MSI X58 PRO-E or X58M settings I would be very grateful.
TIA
MSI X58m
Dram Freq: 999.5mhz
FSB/Dram: 2:12
CMD Rate: 2T
PLL: 1.80
TIA
