F3-12800cl9-2gbrl stable settings!
  • F3-12800cl9-2gbrl stable settings!
    Hi, thank you for helping me! I have four, 2 gig sticks of this RAM and I cannot find detailed/complete timing settings for the various RAM frequencies. I'm trying to overclock my i5 750 but the memory isn't stable. I HAVE been reading up a lot on this forum but I'm NOT looking to "tighten" my timings; just want something stable and default on the memory side of things. I'll likely be running this 1600 speed memory at or below spec just to get it stable...clearly I am frustrated. Why doesn't the G.Skill website have all the timings laid out for us? (CL-RCD-RD-RAS-RC-RFC-RRD-WR-WTR-RTP-tFAW) Anyways, my board is an ECS P55H-A and I just want to know what manual timings I need. Thank you much!!
    They can slightly differ from each motherboard, but if you set the first four, the BIOS will take care of the rest.
      ECS P55H-A mobo
      Hi, unfortunately, when it comes to oc'ing with this MOBO I have to manually set all timings, once I adjust even one of them. It's goofy and clearly more difficult to OC. I could be wrong about the bios settings but this isn't popular with oc'ing so it's hard to find info on it. I do know that others with this board have achieved around 3.9 or more on the i5 750 but do not describe how.
        SPD/XMP
        (9 CL - 9 RCD - 9 RD - 24 RAS - 40 RC - 88 RFC - 5 RRD - 12 WR - 6 WTR - 6 RTP - 20 tFAW)
