ASUS M4A88T-V EVO QVL for GSKILL 4GB Modules?
  • ASUS M4A88T-V EVO QVL for GSKILL 4GB Modules?
    I am going to be purchasing components for a new build computer. I have selected ASUS M4A88T-V EVO motherboard to pair with a Thuban 1100 6x core AMD chip. According to reviews the motherboard is picky about memory to use. However, the QVL on the ASUS website doesn't list any 4GB modules because they were not widely available when the list was published.
    Has anyone on here used GSKILL 4GB modules on this type of motherboard? I would like to use 4x 4GB modules to achieve 16GB memory for the computer (before you ask, yes I will be using a 64 bit operating system).
    Thanks for the help!
    No problem, here are our 16GB kits:
    http://www.newegg.com/Product/Produc...20DDR3%20SDRAM
    I would suggest the
    F3-10666CL7Q-16GBXH
    or
    F3-12800CL7Q-16GBXH
    since these are very high performance modules.
      and are these units verified to work with the motherboard? Apparently its BSOD central with memory it doesn't like....
        i put together a system with the M4A88TD-V EVO and 2 F3-10666CL9D-8GBRL (http://www.newegg.com/Product/Produc...82E16820231311) and i can verify that it worked perfectly for me. i would be surprised if you had any issues with the same setup.
