2X4 8GB choices for Gigabyte 890
  • 2X4 8GB choices for Gigabyte 890
    I am researching parts for another build for a friend.
    Motherboard will probably be a Gigabyte 890GPA or possibly a 890FXA.
    Processor will be either a PhenomII X4 or X6.
    I am looking at either the F3-12800CL8D-8GBRM or the F3-10666CL7D-8GBRH sets.
    Will the CL8D-8GBRM run well if downclocked to 1333 7-7-7-21 and would there be any advantage over the CL7D-8GBRH run at their stock (same) settings?
    I want to stay at 1333 for stability and longevity. It is not a gaming rig.
    Also, are the new Ripjaws X series any different besides the heat spreader redesign?
    Thank you,
    Steve.
    Just get the 8GBRH, for that price it is no question.
    The RipJaws X is for the P67, so it does not benefit this system.
      Thank you for your help and the quick reply.
      Much appreciated.
      Too bad about the X series, they are nicer looking imo.
      Steve
        You can get the XH too, but I just meant there is no performance gain over the RH.
        http://www.newegg.com/Product/Produc...0666CL7D-8GBXH
          Thanks for clearing that up. I thought you meant they wouldn't work.
          Steve
