Need Bios settings i7 930 p6x58d Premium ddr3-2000
  • Need Bios settings i7 930 p6x58d Premium ddr3-2000
    CPU: i7 930
    Motherboard: p6x58d Premium
    gSkill Memory: f3-1600CL9T-6GBRH (DDR3-2000)
    Windows 7 x64
    I had it running at 2000 But would get BSOD When running AVS Video Converter. if I go back to everything auto its fine
    I have 3 Questions With #1 the most important at the moment Since I have only a stock fan.
    1.) What would be the Settings for my configuration to run the memory at 2000Mhz with stock CPU Fan. No Memory Fans
    2.) What is a good Fan for the CPU and Memory if I would want to Over Clock
    3.) What are the Bios setting I would need for my Configuration with the better CPU fan Kit and Memory Fan Kit already installed.
    Thanks Mitch
    Gskill might have these types of settings handy, I'll have to check into it - will try and get something on Sun
      Support
      Anyone?
        1) DDR3-1600, 7-7-7-24, 1.60V. Input that in BIOS and you should be ready to go.
        2) CPU fan, Thermalright Ultra 120, True Black, Silver Arrow / Prolimatech Megahalem
        Memory fan, the G.Skill Turbulence II
        3) Enable XMP, then find the precise QPI/DRAM Core Voltage needed to stabilize DDR3-2000
          thank you I will give these a shot
            I tried
            Ran prime95 for 64bit and it blue screened with in 1 minute.
            then increased the voltage to 1.6250
            It blue screened again after 2 minutes Should I keep trying to increase the voltage?
            here is my Settings can you look it over and suggest anything?
            Could I overclock a little with stock fan or just rum ddr3-2000 with correct settings?
            [HTML]****************************
            AI Tweaker
            Ai Overclock Tuner........... = [AUTO]
            CPU Ratio Setting............ = [AUTO]
            Xtreme Phase Full Power Mode. = [Enabled]
            DRAM Frequency............... = [DDR3 - 1600MHz]
            UCLK Frequency............... = [AUTO]
            QPI Link Data Rate........... = [AUTO]
            ASUS/3rd Party UI Priority....= [ASUS Utility]
            CPU Voltage Control.......... = [Manual]
            CPU Voltage.................. = [AUTO]
            CPU PLL Voltage.............. = [AUTO]
            QPI/DRAM Core Voltage........ = [1.6250]
            IOH Voltage.................. = [AUTO]
            IOH PCIE Voltage............. = [AUTO]
            ICH Voltage.................. = [AUTO]
            ICH PCIE Voltage............. = [AUTO]
            DRAM Bus Voltage............. = [AUTO]
            DRAM DATA REF Voltage on CHA. = [AUTO]
            DRAM CTRL REF Voltage on CHA. = [AUTO]
            DRAM DATA REF Voltage on CHB. = [AUTO]
            DRAM CTRL REF Voltage on CHB. = [AUTO]
            DRAM DATA REF Voltage on CHC. = [AUTO]
            DRAM CTRL REF Voltage on CHC. = [AUTO]
            Load-Line Calibration........ = [AUTO]
            CPU Differential Amplitude... = [AUTO]
            CPU Clock Skew............... = [AUTO]
            CPU Spread Spectrum.......... = [AUTO]
            IOH Clock Skew............... = [AUTO]
            PCIE Spread Spectrum......... = [AUTO]
            DRAM Timing Control
            1st Information: 7-7-7-24-5-88-12-8-24-0
            DRAM CAS# Latency............ = [7 DRAM]
            DRAM RAS# to CAS# Delay...... = [7 DRAM]
            DRAM RAS# PRE Time........... = [7 DRAM]
            DRAM RAS# ACT Time........... = [24 DRAM]
            DRAM RAS# to RAS# Delay...... = [AUTO]
            DRAM REF Cycle Time.......... = [AUTO]
            DRAM WRITE Recovery Time..... = [AUTO]
            DRAM READ to PRE Time........ = [AUTO]
            DRAM FOUR ACT WIN Time....... = [AUTO]
            DRAM Back-To-Back CAS# Delay. = [AUTO]
            2nd Information: 1N-58-58-59
            DRAM Timing Mode............. = [3N]
            DRAM Round Trip Latency on CHA = [AUTO]
            DRAM Round Trip Latency on CHB = [AUTO]
            DRAM Round Trip Latency on CHC = [AUTO]
            3rd Information: 8-8-18-8-8-8-7-6-4-7-7-4
            DRAM WRITE To READ Delay (DD) = [AUTO]
            DRAM WRITE To READ Delay (DR) = [AUTO]
            DRAM WRITE To READ Delay (SR) = [AUTO]
            DRAM READ To WRITE Delay (DD) = [AUTO]
            DRAM READ To WRITE Delay (DR) = [AUTO]
            DRAM READ To WRITE Delay (SR) = [AUTO]
            DRAM READ To READ Delay (DD) = [AUTO]
            DRAM READ To READ Delay (DR) = [AUTO]
            DRAM READ To READ Delay (SR) = [AUTO]
            DRAM WRITE to WRITE Delay (DD)= [AUTO]
            DRAM WRITE to WRITE Delay (DR)= [AUTO]
            DRAM WRITE to WRITE Delay (SR)= [AUTO][/HTML]
              STOOOOOOPPPPP you're going to FRY the CPUUUUUU!!!
              NooOOOoOooOoOOOOOOooOoOooo haha
              QPI/DRAM Core Voltage......should be AUTO.
              DRAM Bus Voltage............. = [1.60V]
              Also, DRAM Timing Mode............. = [1N or 2N]
                OK I corrected that to:
                Also, DRAM Timing Mode............. = [1N or 2N] used 1N
                loaded prime95 it ran then had an error and stopped (unloaded) I loaded it again then BSOD rebooted and hear I'm
                  Try 2N, then one module at a time to make sure all modules are error free.
                  Do you have the latest BIOS? Those settings should work flawlessly..
                  Post the 1st Information numbers so I can check advanced timings.
                    I have the latest bios got it yesterday
                    1st info is
                    I ran prime 95 again lasted 3 minutes then it stopped with application stopped windows is finding a solution then a close application and here I'm
                    Going to test each stick now
                      Ran 1 Pass on each stick with memtest+ Boot-able CD
                      all Passed
                      then put all sticks in 3 of them and did another test got this 2 errors
                      then I rebooted and got a overclocking failed error
                        Try DRAM Voltage 1.65V
                          1.65 gave me a warning. put it on 1.64v and did 1 1/2 passes
                          Took this if it helps lowered back down to 1.60v's by the way after above test
                            Try higher timings like 8-8-8-24. If the same problem persists, the modules may be slightly defective. I can't see why else they are not working properly.
                              That did it got 2 passes and no errors with 1.60 volts and 8-8-8-24
                              Does that mean I'm good to go and how does it effect me from running 2000mhz?
                              What would I have to do to achieve 2000?
