Hi Guys,
Thanks in advance for any advice anyone can offer.
So basically I think I made a mistake. I'm doing a build for a friend and I saw this RAM on the QVL for the Clarkdale CPU Processors on the P7H55-M Pro. What I didn't realize is that the QVL was just for 4 GB of RAM (I think). So I bought two kits and installed 8GB on the board.
The first bit of strangeness is the MOBO auto set the timings to 9-9-9-24 instead of 8-8-8-24 that's printed on the RAM. Even then the machine has actually been quite stable BUT it has randomly restarted a few times (like very few only a handful). This is whether i have it set at 9-9-9-24 or manually at 8-8-8-24 or XMP.
One instance I'm able to repeat the restart (after installing Win 7 x64 and performing the first windows update which is like 65 updates it restarts itself near the end (no BSOD). Interestingly the machine passes most stress tests.
Anyway, I removed two of the DIMMS (I actually received 4 DIMMS that are in sequential order SN wise which was cool) and voila, it makes it through that series of updates with only 4GB installed.
So the question is... are there BIOS settings that will allow me to run 4 x 2GB of this RAM in a VERY stable way or am I better off RMA'ing the RAM back to newegg and getting a 6 or 8 GB kit off the QVL? If this was a personal machine I'd probably just keep it, but I need this to be bombproof and one random restart is too many.
Thanks again!
Chris
Thanks again!
Chris
