System Specs:
CPU: Intel i5 760
Motherboard: Asus P7P55D-E LX
Memory: 8GB, F3-12800CL9D-4GBRL CL9 @ 1.5V
Question:
My system is OC'ed and running at a BCLK of 180Mhz. The memory modules are running at a multiplier of x 8, running at 1440MHz, with a memory timing of CL9 (9-9-9-24) @ 1.50V.
These modules are rated up to 1600Mhz @ CL9 according to the spec sheets. Since I have the modules down-clocked a bit, I was wondering what the tightest memory timing is that I can run with these modules?
CPU: Intel i5 760
Question:
