I have a h55m-usb3 with a i5 680. Which would good ram to compliment this setup?
Here is what I've been looking at.
G.skill 1600 mhz $65
http://www.newegg.com/Product/Prod [...] llFullInfo
G.skill 1333 MHz $50
http://www.newegg.com/Product/Prod [...] 0115230055
Or $55
http://www.newegg.com/Product/Prod [...] 6820231276
Or $49
What do you guys think would work best and be the best bang for my buck(if you have other recommendations I'd love to here them)? Im not looking to oc off the back but would like the option. Would there be a great advantage of going with the 1600 ram? Are all these capatible with the board? I was leaning toward the eco sticks as they are spec'd for 1.35v and seem to have a lot of room to play with, but I have seen some problems with them and this board in the forums even though they are on gigabytes tested list for the board so it makes me unsure.
Any help would be much appreciated.
Or $55
Or $49
