Howdy,
I am looking to get the best performance from my RAM. I recently built my rig that includes:
-EVGA X58-SLI3 (131-GT-E767-TR) with Phoenix Technologies BIOS (ver 6.00 PG)
-Intel Core i7-950 @ 3.07GHz
- G.SKILL F3-16000CL9T-6GBTD (6Gb total)
-Window 7 Ultimate (x64)
I selected the F3-16000CL9T-6GBTD DIMMs because EVGA lists this RAM in the memory compatibility list for their x58 series motherboards (under DDR3-2000), although I don't see their board in G.SKILL's list. The BIOS supports 1600MHz 2:12, 1867MHz 2:14, 2133MHz 2:16 and 2400MHz 2:18. When I set the memory to 1600MHz, the BIOS sets the timings to 11, 11, 11, 29, 88 with command rate at 1t. Also, with voltage on auto it selects 1.700v which worries me, since folks recommend 1.65v or less.
Given the speeds available in the BIOS, what is my best option? Will this RAM run at 1867MHz or 2133MHz? If not, what are the tightest timings at 1600MHz? If I manually lower the voltage to 1.65v, will this cause a problem?
Thanks,
Jonathan
Thanks,
Jonathan
