F3-12800CL7T-6GBPI on P67 MB compatibility ?
  • F3-12800CL7T-6GBPI on P67 MB compatibility ?
    Hello Gskill forum..first post here
    I just ordered F3-12800CL7T-6GBPI for my upgrade (Phenom IIx4 940) to ASUS P6X58D Premium(not yet purchased),but after i stumbled across this thread here i'm leaning toward P67/SB
    My quarry ;is this set of RAM will properly work on one of this MB's ;
    P8P67
    GA-P67A-UD7
    Thank you for your time,i appreciated
    i7 3770K/4770K
    ASRock OCF
    Gskill
    ,Crucial C300,WD black,
    GTX570(972/2300)Corsair HX850W,
    Lite-On 24X,Win 7X64bit,TT Spedo
    Yes, but both are dual channel, so a dual channel or quad channel kit would be recommended. For the P6X58D, the 6GBPI would be recommended since it is a triple channel motherboard.
      Yes they are both dual channel ..i could just add one more stick for total 8GB or use only 2 sticks right?
      i7 3770K/4770K
      ASRock OCF
      Gskill
        Well, yes, but there are no single modules sold. So unless you know 6GB is absolutely enough, a dual channel kit would be recommended.
          yes.. i just realize that after looking all over the net,may have to go with P6X58D premium..don't know if thats the right choice (X58 is still hell of a platform) ,it's kind of sad ,after waiting so long to upgrade
          i7 3770K/4770K
          ASRock OCF
          Gskill
            What do you plan to use the computer for?
            We have some sweet dual channel kits you can get if you want to stick with the P67..
            http://www.newegg.com/Product/Produc...=gskill%201600
            F3-12800CL7D-8GBXH
            F3-12800CL7D-8GBRH
              F3-12800CL7D-8GBXH
              F3-12800CL7D-8GBRH
              I won't do much..benching, gaming,CAD,virtual gibs,..have 4GB right now and the most i have use was around 3.2 GB at one time,8GB would be sweet ,
              is there any place i can get extra 2GB for my set or 2X2GB same RAM ?
              I appreciated your help,thank you Sir
              i7 3770K/4770K
              ASRock OCF
              Gskill
                Have to leave that call to GSkill, should be in Wed
                  Unfortunately no, that's why we highly recommend people to purchase a dual channel kit for a dual channel motherboard, and a triple channel kit for a triple channel motherboard. Unless you are certain you will never need more memory, but it's just no fun to be in this sticky situation.
                    I appreciated all your help and will probably send the 6GB kit back ,have to change my way of buying things (for some reason i always get the RAM first )
                    Thank you !
                    i7 3770K/4770K
                    ASRock OCF
                    Gskill
                      Let us know how it goes
                        Yes ..I will thank you Tman !
                        Received the RAM today...such a sweet looking RAM ,will it be a bad idea if i add a set of this
                        later ?
                        http://www.newegg.com/Product/Produc...82E16820231430
                        i7 3770K/4770K
                        ASRock OCF
                        Gskill
                          hey Tman I opted to keep this set ( looks like new LGA2011 platform is going to be triple channel) and love it
                          Thanks again
                          Uploaded with ImageShack.us
                          i7 3770K/4770K
                          ASRock OCF
                          Gskill
                            Looking good, glad to hear it, Enjoy!
