Two sets of 2x2GB (F3-12800CL9D-4GBRL & GA-870A-UD3)
  • Two sets of 2x2GB (F3-12800CL9D-4GBRL & GA-870A-UD3)
    I'd like to add another set of sticks to my system. I'm running a set of dual-channel F3-12800CL9D-4GBRLs and would like to add a second pair. The current sticks are overclocked to rated speeds (DDR3 1600) with no stability issues.
    Would there be any problems with this?
    Hopefully not.......there can be, as is the nature of the beast and that they were not pretested to work together, but generally, if they don't play well right out of the box, a few voltage adjustments will bring them in line with each other....on a very rare occasion, they just don't work.....so...if buying locally make sure you can exchange them (just in case to save time/etc of having to RMA)
