can F3-17066CL7D-4GBPIS work with GA-ep45t-ud3lr at DDR3-2200?
  • can F3-17066CL7D-4GBPIS work with GA-ep45t-ud3lr at DDR3-2200?
    How to set in BIOS with QX9650 for FSB400 x ?
    May take a heavy OC, possibly higher than 400 FSB and a fair bit of voltage tweaking, may want to check w/ GB they have the mobo rated for up to 2200 DRAM OCed....otherwise I'd probably start at 400FSB, set the DRAM to base timings and voltage, set the CR to 2 and be prepared to play w/ voltages primarily CPU and NB and a little SB
      CPU FSB is always x 4, so it must reach FSB 550 for DDR3-2200. You may need to adjust FSB Termination Voltage, NB Voltage, and such to be stable.
