Will these work with my motherboard??
  • Will these work with my motherboard??
    I wish to upgrade my memory on my motherboard. I have the XFX nForce 790i Ultra SLI
    Will this memory work??
    F3-12800CL9Q-16GBRL
    Thanks,
    -Zooman
    I'll check, but unless they jumped the BIOS, believe the XFX 790i Ultra SLI tops at 8GB...haven't touched one in awhile....be back shortly
      Correct, 8GB max.
        How about this MB?
        Just bought this MB from newegg.
        BIOSTAR T5 XE CFX-SLI LGA 1156 Intel P55 ATX Intel Motherboard
        Will this work with above mem??
        Thanks,
        -Zooman
          Should be fine....any problems, give us a shout
            Will do....thx
              No problem
