Hello Everybody,
I just upgraded my desktop to and im having an issue with the bios only registering 4 gb but when i log into windows it shows a total of 8 gb with 4 gb usable.
The new rig consistes of
ASUS P7P55D-E PRO motherboard
http://www.newegg.com/Product/Produc...82E16813131621
Inel CORE i5-760
http://www.newegg.com/Product/Produc...82E16819115067
GSKILL F3-12800CL9D-8GBRL RAM
http://www.newegg.com/Product/Produc...82E16820231314
I have gone through every forum here and on the asus forums and have had no luck on fixing the problem of only showing 4 gb in the bios and when logged into windows show me having 8 gb with 4 gb usable while running the DIMMS in dual channel. I have run multiple memtests and all pass, I have tried changing the bios to XMP and D.O.C.P and Manual with no change. Checking MSConfig the maximum mem box is not checked and the memory remap is enabled. I have even cleared the CMOS multiple times.
Now if try and run the DIMMS in single channel the bios and windows both show the rig having and using the full 8 gb of ram.
any help with situation will be greatly appreciated.
Thank You,
A very frustrated and lost person.
Inel CORE i5-760
Thank You,
