I'm buliding a new rig. Perhaps I made a mistake. I've got a Rampage III Extreme mobo and got (2) 8GB Ripjaws kits (2 x 4GB PC3 12800). According to the mobo manual, I can install 4 DIMMS by using A1, B1, C1 and A2 but I think I must have screwed up since it's a triple-channel setup and I should really use 3 matched DIMMs, not 4, right?
So, I have two questions:
(1) Will my 4-DIMM 16GB setup work with the (2) 2x4GB DIMMs I bought? If not, can I just use 3 of them to get 12GB?
(2) Can I order another 8GB kit (2x4GB) and run 24GB since I'll have 2 sets of 3 DIMMs?
Thanks!
Thanks!
