Update - Version 3.5a dated 8/24/2010 appears to have a bug when testing more than 4Gb's on my system; but using Version 4.10, dated 04/05/2010 works fine.
My system fails memtest in first 5 seconds with all 3 modules, but each module passes individually.
I have a decent system, i7-950 w/ Freezer Pro2 cooler, 850 watt OCZ PSU, and my SSD and HDD are not connected yet.
Installed hardware and booted Memtest 3.5a in BIOS FB (08/24/2010). System freezes at Test #0, 3%. It freezes at memory 4096M to 6144M - seems to be problem when it attempts to reach second memory module.
Tested each module individually, all pass no problem (using DDR3_1, DDR3_3, and DDR3_5).
Tried tweaking BIOS settings per forum recommendations - CAS from 7-7-7-20-1, 8-8-8-24-1, and 9-9-9-24-2; Frequencies 1600, 1800, and 2000; DRAM Voltage from 1.58 to 1.66 (actual shows 1.648); and QPP/Vtt 1.335, 1.555, and 1.595.
I hesitate to go blinking red on the QPP/Vtt since I should be able to hit the 1.4 to 1.5 range with the 1800/8-8-8-24 settings using a i7-950.
I have also tried two modules (DDR3_1 & DDR3); Channel 0 (DDR3_1 & DDR3_2) and Channel 1 (DDR3_3 & DDR3_4); all freeze at the same point (4096M Memory)
Regretfully, I do not have any other DDR3 motherboard or memory available to cross test with.
Is this a MotherBoard problem or a Memory problem?
Any suggestions?
Thanks,
Any suggestions?
Thanks,
