I recently built a new computer using F3-12800CL9D-4GBRL ram, 4 gigs worth, with the Foxconn A7DA 3.0 motherboard and Windows 7 64 bit. I've been having issues with the system crashing/restarting on it's own while playing games or watching video. I have the ram settings in bios set as auto, but I wanted to make sure they are correct. Here's the setting for the ram via cpu-z . Any help is greatly appreciated.
F3-12800CL9D-4GBRL with Foxconn A7DA settings
Also, memory frequency is currently at DDR3-1333. Raise that to DDR3-1600 in BIOS. You may need to raise CPU-NB Voltage or DRAM Voltage +0.1V to support DDR3-1600. It may be unstable without these settings.
Or you can operate the memory at DDR3-1333, just lower timings to 8-8-8-24 and it should be just as fast as DDR3-1600 9-9-9-24
