I'd like to know what BIOS settings I need to tweak so that the G Skill Ripjaws F3-12800CL9D-8GBRL RAM run at 1600.
I'm a beginner PC builder trying to learn and have just built a PC with the following:
[1] ASUS Sabertooth X58 LGA 1366 motherboard
[2] Intel i7-950 Bloomfield 3.06GHz LGA 1366 CPU
[3] CORSAIR CWCH50-1 High Performance CPU Cooler
[4] EVGA 01G-P3-1465-AR GeForce GTX 465 1GB 256-bit GDDR5 Video Card
[5] G.SKILL Ripjaws Series 8GB (2 x 4GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Desktop Memory Model F3-12800CL9D-8GBRL
[6] Microsoft Windows 7 Professional 64-bit
[7] KINGWIN Lazer LZ-1000 1000W Modular 80 PLUS BRONZE PSU
[8] LIAN LI PC-A05NB ATX Mini Tower Case
For the two RAM sticks, one is placed in A1 and the other in B1. Both Piriform's Speccy and CPU-Z are telling me that all 8gb are detected and running at about 800 MHz at timings of 9-9-9-24. I understand the Sabertooth X58 is a triple channel board and for now I'm using dual channel RAM, but was thinking it still should be possible to get the two G Skill Ripjaws RAM sticks to run at 1600.
Based on some information I found in the NewEgg feedback I've gone into the BIOS and under Ai Tweaker enabled XMP and set the DRAM frequency to 1600, then Exit & Save Changes, but it didn't seem to change anything, so I'm sure I have overlooked something(s).
So, I'd like to know what all BIOS settings I need to tweak so that the G Skill Ripjaws F3-12800CL9D-8GBRL RAM run at 1600.
Thanks for your help.
