First of all, i'm french and my english isn't so good, i apologize...
After reading severals threads here, i still not found an issue :x
That's why i post today.
Motherboard : Asus P6T SE
Cpu : Intel i965
Ram : Kit 3*2GB Perfect Storm F3-16000CL9
OS : Windows 7 Ultimate 64bit
I bought my machine one year ago. I never had 6gb detected, only 4gb, but I didn't try to solve the problem...
But since three months, I lost 2gb more and it's going to be really annoying at this point cause I can't even play some games on my pc..
I read the stickys and the link http://i4memory.com/f54/asus-x58-6-1...stalled-19200/
I tried differents BIOS config like :
Ai Overclock tuner - Manual
Cpu Ratio setting - 16
Intel Speedstep Tech - Disabled
BCLK Freq - 200
DRAM Freq - DDR3 - 2000 (btw I don't even want to OC my ram, 6 gb @1066, it should be just fine at this point...)
UCLK Fred - 4000Mhz
DRAM timiing control
Cas Latency - 9
tRCD - 9
tRP -9
tRAS - 24
Command Rate - 2N
CPU Voltage - 1.30v
CPU PLL Voltage - 1.85v
QPI/DRAM Core Voltage - 1.50v
IOH Voltage - 1.35v
IOH PCIE Voltage - 1.6v
ICH voltage - 1.20v
ICH PCIE Voltage - 1.60v
DRAM Bus Voltage - 1.66v
Load line Calibration Disabled.
Well, if I post, you know the result : no change... still 2gb in the bios and in windows
However, SiW recognize the 3 modules, like Cpu-Z.
So I tried a memtest : Memtest recognize the 3 modules too. Result : 2 pass, no errors....
Then I thought about the slot dimm and try to change the emplacement to test. My 3 modules were on A1, B1, C1. No change after the replacements...
I try with every module single (understand? :x) and here it is : my PC doesn't boot only with one module (call him "good module"
). He boots with him independantly of the slot (A1,B1 or C1).
On the other way, my PC doesn't boot wiith one of the 2 others modules, it turns on, but no "bip" et no bios.... i tried every slot for each module (except A2,B2,C2) and same results : it doesn't want to boot...
I verify and et demount my CPU, for check pin contact, and I also check my heatsink : there is mylar O washers between heatsink's feet and motherboard so it's good like they said in the i4memory.com topic...
I'm out of solutions at this time.... and I don't understand anything anymore... but I can't stay with 2gb with 6 installed :x
Thanks for your advices and help.
Fred
PS : If some sentences are not understanding, let me know... I'll try reformulate it.
Cpu : Intel i965
BCLK Freq - 200
UCLK Fred - 4000Mhz
Cas Latency - 9
tRCD - 9
tRP -9
tRAS - 24
Command Rate - 2N
CPU Voltage - 1.30v
IOH Voltage - 1.35v
ICH voltage - 1.20v
Fred
