This is my 1st build and i have the above with a Phenom II X4 970 BE C3 and though everything fired up on 1st boot, the sticks defaulted to 1333 at dual channel mode and everything runs smooth at this with no errors, issues and passed memtest and prime95. Also, mobo purchased have bios rev 2.2 (i believe is latest version).
However, with everything else at auto, i tried to manually set the timings to 1600 as per product specs 8-8-8-24 2T v1.605 also tried at 1.65, CPU NB Vid at 1.2 (auto). I've researched in other forums but its still giving me some stability issues (i.e. bsod, random shutdowns).
I'm dumbfounded and finally realized that i need to ask the experts on this, that's why i came here and would like to ask for assistance on having my rig run stable at spec. i'm not really tech savvy, so if you can please use details and simple terms, that'll be appreciated.
Thanks...
My apologies if there is a similar thread where i should have posted this but i tried to search for a same case as mine but couldn't find any.
Thanks...
