Hi
I am looking for timings and settings. Looked through the thread tried different settings no go time to ask for help. The techs here are good always help out. I can get my CPU 4.0 (air cooled) at stock mem speed but if I do anything with the mem I get BSOD. I can get mem to 1800 with CPU at 3.5 but still a little flakey. Is it best to go lower CPU higher mem or vice versa. Should I loosen timings? to get both. If I have to I will enter all manually. Would like to push both to the max.
Thanks to all who can help
Asus Maximus III Formula (BIOS 2001)
Mem-RipJaws F3-12800-CL7D-4GBRM Timing- 7-8-7-24 2T
CPU- Intel i7-860
NoctuaNH-U12P CPU Cooler
GPU- ATI 4870 512M (Not overclocked)
Power 1000 ultra X3
Intel SSD X25-V 40GB (Non- Raid)
Windows 7 64bit (New Install)
Current settings
AI Overclock Tuner: XMP
Xtreme Memory Profile: [Profile 1]
CPU Ratio: 18
Intel Speed Step: Disabled
BCLK Frequency: 180
Dram Frequency: DDR3-18000MHz
QPI Frequency: 6302MHz
CPU Clock Amplitude:Auto
PCH Clock Amplitude:Auto
CPU Clock Skew:Auto
PCH Clock Skew:Auto
Extreme OV: Disabled
Full Phase Control: Full Phase
Load Line Calibration: Enabled
CPU Voltage Mode: VID
CPU Volts:1.36250
CPU PLL:2.014
IMC:1.40450
PCH:1.04675
Dram:1.61650
Dram Data Reff Voltage Chan A: Auto
Dram CTRL Reff Voltage Chan A: Auto
Dram Data Reff Voltage Chan B: Auto
Dram CTRL Reff Voltage Chan B: Auto
CPU- Intel i7-860
Power 1000 ultra X3
Current settings
CPU Ratio: 18
BCLK Frequency: 180
CPU Clock Skew:Auto
PCH Clock Skew:Auto
CPU Volts:1.36250
CPU PLL:2.014
IMC:1.40450
PCH:1.04675
Dram:1.61650
