I bought the F3-10666CL9D-8GBSQ (DDR3 1333 (PC3 10666)) from an online retailer and the computer started with clicking noises on boot up, blue screen errors all the time with any app running, icons on desktop permanently flickering, not able to open folders on Windows Explorer, freezing, erratic behavior all over the OS (Windows 7 x64 Ultimate), and impossibility to use the system all around.
I tried the modules one by one and they work separately but not when I put them together. I also updated to laptop BIOS to v.A10 with no positive result at all. As a matter of fact, it was hard to get the machine acting correctly after several clean installs of Windows. It was like some cache saved the bad configuration or corruption on the BIOS.
As soon as I went back to the factory Hynix HMT325S6BFR8C-H9 (2x2GB) all went back to normal. I am now wondering if I should request a replacement or just a refund, since I don't know if the replacement will act the same.
I would appreciate technical comments from G.Skill specialist on this issue.
Dell Vostro 3400
Intel HM57 chipset
Intel Core i5 460M CPU
Hynix HMT325S6BFR8C-H9 (2x2GB) factory RAM
NVIDIA GeForce 310M (512 MB) Video
Seagate Momentus XT ST95005620AS HDD
Dell Vostro 3400
Intel HM57 chipset
