Hi, I'm in the process of overclocking my system, and have found the best balance of OC/temps @3.8GHz (181x21). So my RAM is running at 1448MHz (x8), but this is under spec. The next step up is 1800MHz, which renders my system unbootable. So my question is: can I OC my RAM to 1800MHz? Can I just increase the voltage on them (there rated at 1.60, and Intel "allows" up to 1.65, so I as far as my CPU & MB are concerned I can up the voltage up to .5)? Or should I go for tightening timings (I'd think this is more complicated and since the performance difference between upping the clock speed and lowering the timings is about the same, I'd rather go for a higher speed)?
Memory OC?
Originally posted by Tradesman View PostBest bet may be to set everything manually..... set the speed to 1600, the base timings, DRAM Voltage and CR (Command Rate to 2) rather than use XMP or Auto or linked.
Originally posted by Tradesman View PostIn the BIOS go to the OC Tweaker --- Overclock Mode -- Manual
That enables untied (or linked) OCing, so you can manually set the DRAM
Originally posted by Tradesman View PostDO you have the latest BIOS? Might want to check w/ ASRock, they've provided me w/ good turn around on email support
If you follow Intel's suggestion, then all you can do is raise DRAM Voltage to 1.65V and see if it will be stable with DDR3-1800. Technically you can go beyond this, but you also need to set QPI Voltage.
Try your DDR3-1810 setting with 1.65V and see if that is stable. Part of overclocking is finding voltages that can stabilize the frequency without damaging hardware.
Keep us posted on the results.
Originally posted by GSKILL TECH View PostIf you follow Intel's suggestion, then all you can do is raise DRAM Voltage to 1.65V and see if it will be stable with DDR3-1800. Technically you can go beyond this, but you also need to set QPI Voltage.
I'm waiting for your reply to hit the button
No problem!
Overvoltage is OK if done correctly. The higher frequency will use the extra voltage, so it does not damage the memory. But if you set DDR3-1600, and shoot it up to 1.80V because your memory is not stable, than you're probably going to fry the memory. Key is to do research so you know what you are doing. (as you have done) Along the way you will learn and become more familiar with your system.
GSKILL TECHLast edited by GSKILL TECH; 12-02-2010, 04:29 PM.
Originally posted by GSKILL TECH View PostNo problem!
GSKILL TECHI'll update you with the results.
Edit:
IT WORKED! I'm now testing with memtest, about 2 passes should be enough to tell if it's stable, right? When I have time I'll do an over-nighter.
Memtest only tests the memory, you will want to use Prime95 or some stress test to make sure the entire system is stable, along with the memory.
Glad to hear it worked.
If you want to be "overclocker" precise, test for the lowest stable DRAM Voltage and QPI Voltage. The QPI Voltage especially can vary on AUTO, so manually setting this would be best.
GSKILL TECHLast edited by GSKILL TECH; 12-02-2010, 04:42 PM.
