I am currently having problems with the BSOD on my pc. I have the above mb & memory and a intel core dual quad 3ghz CPU. I loaded windows 7 64 bit and I changed the first 4 timings to you specs to 7-7-7-21 and left everything else on auto. Am I setting the bis wrong. Or do I have to set these sticks to different timings since I am using win7 64bit
The rest of the settings in my bios contain the following......
Dram CLK skew on channel a1,a2,b1,b2
Dram read training, dynamic write control, write training, etc. I left these settings alone on AUTO
I only changed ....
Cas# latency to 7
Dram ras# to cas# to 7
Dram ras# precharge to 7
Dram ras# activate to recharge to 21
Ras# to ras# delay ... Kept on auto
Row refresh cycle time kept to auto
Writer recovery time kept to auto
Ect rest is on auto
Is there anything I messed up ?
-mike
I only changed ....
Cas# latency to 7
Ect rest is on auto
-mike
