Motherboard: GA-890GPA-UD3H rev. 2.0
Memory: F3-12800CL9-2GBRL (x2)
CPU: AMD Phenom II x4 955BE stepping 3
BIOS: Version FE
When I put my PC together I was under the impression that my memory would be operating at the 1600Mhz that I bought it for. After looking through CPU-z I find that it's running at 1333Mhz.
Being a Revision 2.0 motherboard it states the maximum Mhz is 1866, that is far more than what my ram is stated at so it should be able to handle it at it's rated 1600Mhz.
What I'd like to know is what are the settings I should use in the BIOS and what program I should use to test that it is stable and won't crash or corrupt my PC.
I should note that I threw away the packaging the memory came in.
Thanks.
BIOS: Version FE
Thanks.
