I have a set of gskill flares I just bought..I put them in today..and know matter what I do I can not get them to boot at 2000mhz..they will run 1600mhz just fine..I tried adjusting the CPU-NB voltage and speed..from 2500mhz to 3000mhz with 1.35volts..won't post at 2000mhz but will at 1600mhz with that CPU-NB setting...my 1090T is overclocked at 4ghz and runs fine with 1.45volts..my HT is at right now 2600mhz..but when I try for 2000mhz with the memory..the HT is set at 2500mhz..I was told by gksill before buying the flares..That the MSI NF980-G65 would have NO problem running this memory at 2000mhz..As long as I had the 1090T..So far WRONG..So if anyone has any clues or ideas..what I need to set different..Really would thank yea...
And also did set the memory volt at 1.65 like it said..and the timings 7-9-7-24 and also tried 8-8-8-24 and 9-9-9-24..none worked at 2000mhz
