Hello
Current setup:
MSI785GM-E51 mobo, Phenom IIx4 955 (C3 revision), 4GB of OCZ Gold 12800 memory oc'ed to 1600.
BIOS settings:
CPU ratio: 16.5 = 3300
FSB/DRAM 1:4 = 1600
DRAM voltage 1.71
Memory setting: 8-8-8-24, 2T
Unganged mode: Enabled
I want to add 4gb of F3-12800CL9D-4GBRL to this.
Will it work with what I have, since the gskill has 9-9-9-24?
Current setup:
BIOS settings:
FSB/DRAM 1:4 = 1600
DRAM voltage 1.71
